CLI with --project= option and revision number
Hello Support,
in the CLI si viewproject --project="#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test"  how do I provide the sub-project revision number on the development path dev_test?
--projectRevision= is not allowed because --project= option is being used.
Eagerly waiting.
Thank you.
    LLawtonAnswer
    Hello Pashan,
    Then I don't understand the question because my example works and it does use projectRevision with the project option.
    I have never seen this syntax in the CLI: "#p=/root_project/project.pj#s=sub-project/project.pj#d=dev_test", so I may be confused.
    Have you tried the syntax I proposed, especially example #2?
    If you want a specific checkpoint (project revision), you don't have to specify the devpath since it's already implied.
    Sorry, that's all I have.
    I think you want the "--devpath" option.
    From the example you provided, the command would be:
    si viewproject --project="/root_project/sub-project/project.pj" --devpath=dev_test
    You could also try:
    si viewproject --project="/root_project/sub-project/project.pj" --projectRevision=1.3.1.5
    In this example, your dev path started from main line checkpoint 1.3 and has a number of checkpoints
    Notes:
    - The two commands are not strictly equivalent depending on context, but I include them because you did mention projectRevision.
    - No need for "#", and there is no distinction between project and sub-project in this case.
    - You can type "si viewproject -?" for syntax and all options (true of any command).
    pnone1-VisitorAuthor
    Hello Laurent,
    That will not work, because when you use --project= option then --projectRevision= will not be accepted. That's what my question was. When I use --project= option, then how do I mention the version number in the CLI for "si viewproject" command.
    Hopefully my question is clear.
    Thank you.
    LLawton16-PearlAnswer
    Hello Pashan,
