Configuring the "Finder Dialog" in Integrity Possibility exclude documents
it is possible to exclude documents (e.g state Obsolete) in the document finder?
Thanks in advanced
    This is in fact possible. In the Document Finder, when you click on the "Select..." button, this opens the item finder. This screen searches for items based on a query. By default this is the Quick Query, but you can use any query you like to search your items. A custom query can be made that excludes states, or just about any other condition you like.
    Jeremy yes that is right I can configure a query for the left window( in our case projects) on the right window I can see all the documents for the selected project on the left.
    How can I now configure that I can only see documents for example with the state Released on the right window
    Unfortunately, the Outline pane is just an expansion of the info from the query, and does not have any sorting capability. If you needed to exclude results, this would have to be done in the query itself.
