May 10, 2016 6:21 AM UTC
Connection between PTC Integrity and IBM Rational Products
Is it possible to connect PTC Integrity with IBM Rational Products like Rhapsody, Change or Synergy?
    May 11, 2016 2:13 PM UTC
    Hello Vanessa Urban‌,
    It's possible, and there are implementations that have been done by our Global Services team.  Please contact your Account Manager to discuss this with them.
    Regard,
    Kael
    Nov 16, 2018 8:43 PM UTC
    Hi Team,
    Earlier I was using an ImsIntegration profile(.sbs file) for importing requirements in rhapsody. Till IMS version 11.0 the integration worked well. But recently we upgraded or client and IMS server to 11.2 version. Since then the integration fails. Need your help with this. Please find the error message below:
    IMS PSS Requirement Synchronization: Version 2016-04-18
    Command execution on IMS server failed! com.mks.api.response.CommandException: mks.frame.app.ui.ViewException
    finished.
    Nov 19, 2018 3:53 PM UTC
    Do you know the Integrity command that is being run here, and which version of the Integrity API is being used?
    Were there any errors in the Integrity logs?
    Jan 22, 2019 2:28 PM UTC
    So do the possibilities also include connection to IBM ClearQuest? Or to what requirements should another software tool have in order for it to integrate with Integrity?
