creating story via API
I am creating a story via the API
im createissue --user=nshaikh --port=7001 --hostname=integrity.ptc.com --type=Story --addRelationships=Epic:168598 --field=Description=This backlog to develop 3rd Party Adapters Automation. --field=Current Estimate=16 --field=Scrum Team=3rd Party Adapters WPD --field=QA Required=false --field=Story Type=Story --field=Acceptance Criteria=Planned automation work completed. --field=Primary Segment=PLM --field=Summary=[Auto] 3PWGM - Adapters Automation - 1508 --field=Assigned Users=nshaikh --field=Product Owners=youkim --field=Pubs Required=false --
this returns with error
Failed with exception: Could not save item: MKS124066: Field "Epic" does not exist.
com.mks.api.response.impl.XMLResponseImpl@1188e820
This was working before Integrity migrated to new version
what is the fix for this
    I did some investigation and then came up with the solution
    use "Backlog Item For" instead of Epic
    eg.
    im createissue --port=7002 --hostname=integritydev.ptc.com --type=Story --addRelationships="Backlog Item For":168598 --field=Description="This backlog to develop 3rd Party Adapters Automation." --field="Current Estimate"=16 --field="Scrum Team"="3rd Party Adapters WPD" --field="QA Required"="false" --field="Story Type"="Story" --field="Acceptance Criteria"="Planned automation work completed." --field="Primary Segment"="PLM" --field="Summary"="[Auto] 3PWGM - Adapters Automation"  --field="Assigned Users"="nshaikh" --field="Product Owners"="youkim" --field="Pubs Required"="false" --field="Product Line"="Windchill Core"
    IMHO the problem lies in "--addRelationships=Epic:168598"
    As for the I10.6 CLI document this parameter is deprecated.
    You should use "--addFieldValues=Epic=168598" instead
    HTH
    I tried via API doe snot work
    I also tried via the im utility (see below)
    D:\Program Files (x86)\Integrity\IntegrityClient10\bin>im createissue --user=nshaikh --port=7001 --hostname=integrity.ptc.com --type=Story --field=Epic=168598
    Creating Story ...
    *** Could not save item: MKS124066: Field "Epic" does not exist.
    Hello Nazeer,
    Could you provide the output of this command:
         im viewtype --user=nshaikh --port=7001 --hostname=integrity.ptc.com Story
    Specifically, what we're interested in here is whether the field Epic exists.  Is Epic actually a type?  If so, is item 168598 an item of that type?  If so, is there a relationship field which connects a Story to an Epic?  It is likely that relationship field's name which should be used in the place of Epic when using --addFieldValues=<RelationshipField>=168598.
    Kael
