Oct 22, 2019 7:40 AM UTC
Creating Test Session with defined parameters - MultiValue issue
I'm developing software, that is creating test session based on test specification, and i already handled getting data from PTC, but i can't create Test Session using CmdRunner.
 try
 PTC.Command Cmd = new PTC.Command(PTC.Command.IM, "createissue");
 PTC.MultiValue mv1 = new PTC.MultiValue("=");
 PTC.MultiValue mv2 = new PTC.MultiValue("=");
 PTC.MultiValue mv3 = new PTC.MultiValue("=");
 mv1.add("Summary");
 mv1.add("AutoSessionTest1");
 mv2.add("Project");
 mv2.add("/MySampleProject/Electronics");
 mv3.add("Test Objective");
 mv2.add("473680");
 Cmd.addOption(new PTC.Option("type", "Test Session"));
 Cmd.addOption(new PTC.Option("field", mv1));
 Cmd.addOption(new PTC.Option("field", mv2));
 Cmd.addOption(new PTC.Option("field", mv3));
 PTCResponse.Response R = InputEngine.Run(Cmd);
 MessageBox.Show("Test Session Created");
 catch (Exception exc)
 MessageBox.Show(exc.Message);
Do you have an Idea why it won't work?
Best regards,
Chris
7-Bedrock
Oct 23, 2019 6:38 PM UTC
haven´t used MultiValued for some time now, but I believe you only have to use it that way
 Option fieldOption = new Option("field");
 MultiValue multiValue = new MultiValue("=");
 multiValue.add("fieldName");
 multiValue.add("fieldValue");
MultiValue multiValue1 = new MultiValue("=");
multiValue.add("fieldName1");
multiValue.add("fieldValue1");
// Add the MultiValue object to the Option object. fieldOption.add(multiValue);
fieldOption.add(multiValue1);
the integrations builder guide unfortunately has no sampe, this is copied from the javadoc..
I personally don´t use multivalue
you can also add the same command option multiple time, e.g.
Command cmd = new Command(Command.IM);
cmd.setCommandName("createissue");
cmd.addOption(new Option("field", "Shared External ID=123456"));
cmd.addOption(new Option("field", "Summary=Summary_123456"));
if you want to do troubleshooting you can try running the command using CLI, then you should get a proper error message.
you cannot rely on ex.getmessage(), sometimes the ex has a nested one. the builder guide pdf has some good samples
Phil
Oct 23, 2019 1:14 PM UTC
What message are you getting back when it fails?
7-Bedrock
Phil
kbi1-VisitorAuthor
Oct 28, 2019 12:21 PM UTC
It works your way,
Thanks a lot!
