Duplicate Checking in Trigger
My item has kind of composit primary key. Combination of 4 fields make my Item unique. Somehow duplicate checking functionality offered by Integrity is not helpful or not working for me.
I created Unique Name field, and populated this field via pre-triggers. Now before I commit this item, I would like to check uniqueness of this calculated string but I do not find any direct call to get items based on string value. Neither the query is allowing to dynamically substitute parameter and execute.
What would be best suggession or solution in this case for duplicate checking?
Thanks for reading my post,
Regards
Adhik
mrumpAnswer
Hi Adhik,
a trigger like this should do (see attachment)
* creates the Command to Run the temporary Query
* @return Packages.com.mks.api.Command queryCommand
function getRunQueryCommand()
var queryCommand = new Packages.com.mks.api.Command(Packages.com.mks.api.Command.IM, "issues");
queryCommand.addOption(new Packages.com.mks.api.Option("fields", "Type,ID"));
var queryBuf = new java.util.StringBuffer();
queryBuf.append('(');
queryBuf.append("field[");
queryBuf.append(singletonField);
queryBuf.append("]=");
queryBuf.append(currentValue);
queryBuf.append('"');
queryBuf.append(')');
queryCommand.addOption(new Packages.com.mks.api.Option("queryDefinition", queryBuf.toString()));
return queryCommand;
* check whether the temp query finds at least one Item of the same value as the current Item
* @return true if successful; else always false
function check4Singleton()
// Create an API Object to run IM Command Line commands
var api = environmentBean.createAPISessionBean();
// Execute the Query command
var runQueryOut = api.executeCmd(getRunQueryCommand());
if( createQueryOut.getExitCode() == 0 ){
logDebug("Successfully run temporary Query");
if( runQueryOut.getExitCode() == 0 ){
// analyse result
if (runQueryOut.getWorkItemListSize() == 0 ){
logDebug("no duplicate found, proceed");
return true;
else{
print("found "+runQueryOut.getWorkItemListSize()+" Item(s) of the exact same value for Field "+ singletonField );
logDebug("abort");
return false;
else
print("Failed to run temporary Query");
logDebug("leave check4Singleton()");
return false;
} // END if( createQueryOut.getExitCode() == 0 )
else{
print("Failed to create temporary Query");
return false;
mrump16-PearlAnswer
Hi Adhik,
// analyse result
return true;
else{
logDebug("abort");
return false;
else
return false;
else{
return false;
akadam1-VisitorAuthor
Thanks Matthias,
With little tweaks it worked. Now I have to make it generic enough so that others can use too like library function.
Regards
Adhik
