Jan 22, 2015 2:49 PM UTC
Duplicate field value in Trigger
I have an Integer field created (Integer_fld) and would like to create a trigger that checks for duplicate values for previous created items items.
I tried a script from a previous discussion, but could not make it work. I thought I would start a new discussion for this.
EXAMPLE:
List of Items
ID State Integer_fld Txt_fld
100 Initiate 10023 Some text here...
101 Initiate 10024 Some more text here...
I create a new Item ID 102 and for the Integer_fld I enter 10023. When I try to save it I would like to see an error message stating it is a duplicate. ID 100 has the same value in the Integer_fld.
Thank you,
Dan
    Jan 23, 2015 7:57 AM UTC
    Hi Daniel,
    there is another post that already covered this problem
    Re: Duplicate Checking in Trigger
    Can you specify whether your current problem is different?
    HTH Matthias
    DanR.1-VisitorAuthor
    Jan 23, 2015 2:02 PM UTC
    Matthias,
    I started a new discussion because the script from that discussion did not work for me. I tried the one attached to the discussion. I'm simply trying to compare an Integer field of a new issue compared to all existing issues. The comparison would check for duplicate and if there was an error message would be displayed. This would obviously be a pre-event trigger.
    Feb 2, 2015 6:53 PM UTC
    I thought this would be easy and someone might have a workable solution. I believe my use case example provides enough information.
    Feb 3, 2015 8:13 PM UTC
    I'm assuming that the problem here is that this code compares strings and you are looking to compare integers.
    this:
    queryBuf.append('(');
    queryBuf.append("field[");
    queryBuf.append(singletonField);
    queryBuf.append("]=");
    queryBuf.append(currentValue);
    queryBuf.append('"');
    queryBuf.append(')');
    Produces a query that reads: if (field[ExistingStringValue]="InputStringValue") ...
    Working with integers, I'd use something more like: if (ExistingIntValue.equals(InputIntValue)) ...
    Try rewriting the query building lines to work with integers instead of strings and it should work for you.
