2-Explorer
Aug 15, 2018 9:29 AM UTC
"Dynamic" / user defined pick fields?
Hi there,
is it possible to have a field that is like a pick field (drop down menu), but the content of the pick list is "dynamic". Means: a user can add some text (either directly in the field or somewhere else) and the pick list gets a new entry. So, the pick list is not pre-defined, but adds up every time someone adds a text.
Regards
Timo
Aug 16, 2018 2:39 PM UTC
Hi @nxpet,
Best solution for such requirement seems to be the IBPL field.
Whenever user want to add new value to the picklist, he/she need to create a new object of that type and it's value will appear in the picklist(Dropdown) and also this will be helpful if user wants to remove any value.
Chirag Agarwal
Aug 16, 2018 6:15 AM UTC
Hi @nxpet,
May i know where you are planning to capture those pick values from User like where user will input those values ?
Some Integrity Object or outside in a form or any other ?
Kapil
nxpet2-ExplorerAuthor
2-Explorer
Aug 16, 2018 9:50 AM UTC
It's not yet defined. Depends on the possible solutions that exist for my problem.
Best solution from user view: The drop-down / pick field itself; so either you take one value from the pick or insert a new value as in a text field. I assume, that this is not possible. So an entry in an object might also work.
Do you know a solution that might work?
Regards
Timo
