6-Contributor
ECU Test linkage with Windchill RV&S
Does anyone have experience with ECU Test(Test management tool) integration with Windchill RV &S 12.4.
Any documentation will be helpful.
Thanks in advance!
Regards
Khushboo
Hi @ksingh-4
OOTB may be not. But as Windchill RV&S 12.4 is very flexible provides various possibility to do integration (Custom Interface using JAVA and CLIs, Web Services, RestAPIs etc.)
So you need to check what possibilities ECU Test Tool provides in terms of Commands, WebServices, REST etc. And then you can decide how architecture of integration will be.
Also depends on your individual use case and need in terms of you would like to exchange data one directional or bi-directional. Things could differ.
Vielen Dank / Many Thanks,
Kapil Jain
Hello Khushboo,
ECU Test is developed by a German company TraceTronic.
Please talk to them directly, they offer an integration already.
Volker
