Oct 23, 2018 7:51 AM UTC
Edit Test Step by Java API
I've found that It is possible to edit a test step using the CLI with:
tm editresult --stepVerdict="stepID=216:verdict=Passed" --sessionid=228 78.
However when I try an equivalent command using the Java API I get an error:
Could not save modified test result: Invalid step verdict value specified: "stepID=216:verdict=Passed"
Can anyone please advise on the correct syntax to use within the Java API to perform this command?
I'm using ILM version 12 server.
awalshAnswer
Oct 25, 2018 3:19 PM UTC
I was able to edit the test step verdict with the following code:
import java.util.*;
import com.mks.api.*;
import com.mks.api.util.*;
import com.mks.api.response.*;
public class sample {
 public static void main(String[] args) {
 try {
 Command cmd = new Command("tm", "editresult");
 Option testStep = new Option("stepVerdict","stepID=568:verdict=Passed");
 Option sessionID = new Option("sessionID","1638");
 cmd.addOption(testStep);
 cmd.addOption(sessionID);
 cmd.addSelection("572");
 IntegrationPointFactory factory = IntegrationPointFactory.getInstance();
 IntegrationPoint ip = factory.createIntegrationPoint("localhost", 7001, 4, 16);
 Session s = ip.createNamedSession("mySession", null, "tester", "password");
 CmdRunner cr = s.createCmdRunner();
 Response r = cr.execute(cmd);
 Result res = r.getResult();
 ResponseUtil.printResult(res, 1, System.out);
 } catch (APIException e) {
 ResponseUtil.printAPIException(e, 1, System.out);
The output is:
Result:
 Message = Edited test result
awalsh5-Regular MemberAnswer
import java.util.*;
 try {
The output is:
Result:
Oct 25, 2018 7:10 PM UTC
Thank you very much and I can confirm this works perfectly.
