eMail notifications
How can I make the email notifications show the link(s) in HTML format, i.e. clickable link?
    Hello Daniel,
    Is this an item notification, or an email sent by a trigger?
    Kael
    DanR.1-VisitorAuthor
    Both.
    If you're using emailAdvanced.js, you'll want to use <%ID%> for the ID number. If you want to do a link to an issue in email, you can generate an HTML Anchor using the general form:
    <A HREF="http://ptcservername:portnumber/im/viewissue?selection=<%ID%>"><%ID%></A>
    and it will generate a link with the item number.
    That I already knew. The emailAdvanced.js was easy.
    Thank you for your response.
    Anyone???
    Anyone?  Please.
    Modifying emailAdvanced for this purpose is not practical, it's a massive script.
    I have the same problem and I've decided to come up with a report that shows all the items I want to include in one email, then send a simple email with a link to the report. Actually, as I write this, I realize it could simply be a query and bypass the report altogether.
    The problem is, I don't have time currently to do it, it's probably going to be a few more weeks before I get to it. When I have it, I can share my solution.
    That is, assuming I understand this thread correctly. If you read the initial question, it's impossible to guess it's about the scenario explained in the 5th response.
