Jul 26, 2018 9:06 AM UTC
Error message of item editibility
I have made a rule of item editibility. But I want to show my custom error. Is it possible?
Jul 27, 2018 7:24 AM UTC
Message that you want to show during Item Editability is set by Integrity. I know setting Custom Message there will be quite useful for end user understanding but i havn't found any option doing this. I am not sure but i don't think this is possible by direct customization. May be trigger code or JAVA API can help but still very few chances.
Kapil
Aug 16, 2018 2:57 PM UTC
Hi Pratik,
Custom error messages can be created using constraints so if can create any constraint similar the editability without impacting any functionality, then your purpose will be solved.
Chirag Agarwal
Aug 17, 2018 9:42 AM UTC
Hi @chirag_kpit,
What do you mean by creating constraints here that can produce custom error message ? Can you please come over again on this and explain more about this ?
Grube,
Kapil
Aug 17, 2018 10:26 AM UTC
Hi Kapil,
Yes, we can add custom error message in constraints. While creating constraint there is button "Customize". Using this you can create your own custom message.
Chirag Agarwal
