Jul 17, 2018 1:48 PM UTC
Exporting document from Integrity using Integrity Gateway Export doesn't work as expected
- 1 reply
- 3435 views
- Translate All
Hi All,
After I export a document from Integrity using Integrity Gateway Export Wizard, the behavior of exported document doesn’t seem consistent. There are few instances where I have encountered error message and export file doesn’t work anymore after the error message, even after I undo the changes it doesn’t work:
- In exported word file, many empty lines in between heading and comment appear.
- If an import document I change the CAPS setting of Heading 1 (removal of the “All caps” setting) export functionality doesn’t work anymore.
- A simple change to Heading 1 like changing the font size from 14 to 12 gives an error.
- I want to add two headings before table of contents (TOC) if I do so even then I get an error. So I tried placing my two headings after table of contents (TOC) I got the same error.
- Our requirement is company logo to be displayed at end of the last page in the exported document. But when I try to put the logo at end of document it gives me an error message (it use to work fine previously but any small changes in document make everything stop and I get an error message).
Any small changes in import file stop the export functionality and I get ‘MKS Gateway’ with an error message (as attached)
If any of community member has faced anything similar to this could you please share your experience how did you make it work?
Thanks in advance.
Shilpa
