exporting result from CLI command into XML
Good Morning,
I apologize if it is a dumb question as I very new to this .
We have a requirements in which I have to collect data via PTC integrity tool. I am thinking of creating batch file but before I want to run command manually to make sure I am getting desire results.
I get the results by running
im issues --query='query name' <== That will give me result in the CLI window
I am just wondering if I can get the result(s) in XML. and then run the next command which is
im viewissue <id>
and get the result in xml file.
Hope I explained it properly
Hi
You could use the --xmlapi flag and redirect output to a file.
--xmlapi won't be supported anymore in the future.
Using Java API instead of CLI is recommended.
Kind regards.
Thierry
mkhan-21-VisitorAuthor
ok Thank you. it worked. In order to process the xml file to get the ID so I can run the Viewstate command. what is the right command to use.
attached is output I just need the value of ID field.
<<Fie
for future use I don't even know where to look for Java API. can you help as well?
Thank you for your help
The MKSAPIVIEWER command-line utility may be your best bet. It's a wrapper for the JAVA API that accepts most (perhaps all in 10.9) IM and SI commands and outputs them as XML.
mksapiview --iplocal --xml im issues --query='query name'
As was previously mentioned, the --xmlapi option will not be supported in the near future. It wasn't correct in many cases anyway. the MKSAPIVIEWER should have a longer life and doesn't require any additional coding.
