For C#; what is the code syntax for for this CLI? [tm editresult --field='Actual Result'='60' --sessionID=509239 622815]
What syntax is needed using the C# API for the following Command LIne Interface
I have tried
issuesView.AddOption("field", "'Actual Result'='" + resultString + "'");
and the error states /"Actual Result/" does not exist
    Not sure if you're still looking for this, but if I understand what you're looking for, then here's what I would use assuming "Actual Result" is a custom field:
    issuesView.AddOption("field=Actual Result", resultString);
    I am using C# with Integrity 10.5 also.
    Is "Actual Result" the field name or is it an overridden display name? You need to provide the absolute field name which could be different than it appears when viewing the items.
    rteifke1-VisitorAuthor
    That is the correct name otherwise the CLI would have the same issue, but the CLI works.
    BTW: Using  10.5.0.5479 version of Integrity with API of 4.13.5479
    if that means anything
    I'm not all that familiar with the C API, but have you tried not having Actual Result wrapped in single quotes?
