FVA fields kills document performance
We have been facing performance issues in our document managment for a while since we've updated from 10.6 to 11.1.
The symptoms are as follows:
- view/edit live documents works normally
- "view as of" for doucments is extremely slow (up to several minutes before a 10 node document opens)
- "view document differences" is extremely slow (up to several minutes before a 10 node document difference view opens)
- "Edit in Word" - workin with a single node is ok, but useing the chapter or entire document option is extremely slow (up to several minutes - sometime even errors in a timeout)
The behaviour was not consistant over all our segment and node types (some where extremely, while others worked much faster), so I took a deeper look into our setup and found this:
IMHO there is a general problem in the handling of FVA multi-valued user fields when it comes to historical operations.
In our node setup of the affected segment types we have a FVA field "project authors" which is referencing a multi-value user field in the project backing item.
It's use was to allow editability rules on the nodes like .... and "project authors" = -current user- ....
I first removed all rules (editability and visibility) for fields and the node itself which had no effect.
But when i removed the "project authors" field from the node type's visible fields definition,
I saw an incredible performance boost (seconds instead of minutes).
Re-adding the field decreased the performance instantly to the slow values i had before.
Removing the FVA field speed up the system again.
For cross checking I added a different FVA "project stakeholders"- again referencing a multi valued user field from the project backing item- , that was never part of the node type before.
The new field decreased the performance instantly to the slow values i had before.
Has anybody made the same experience?
I'd like to hear your thoughts
BTW:
Of course I initially made an case with ptc support (but after 2 week I still got no helpfull answer yet)
Hi mrump,
Is your Support case still open and being investigated, to reference?
Are you using Oracle?  In regard to the FVA/performance issue, I think I recall Support seeing that enabling FVA fields as columns inside the document view significantly affected open document performance, so perhaps you could be seeing something like that?
I think in that case, some Oracle tuning/skipping nested loops was required.
mrump16-PearlAuthor
Hi @MichaelChatel,
thx for the response.
YES we are using Oracle (as it was recommended by PTC years ago).
Just to be absolutely clear on this; the FVA field is not to be displayed in a (document-) view. Actually it is not even part of the node's presentation template.
Just having a multi-valued User FVA referencing your Project Backing Item in the node type's list of visible items is enough to trigger the problem.
PTC support provided a 1.st patch this morning (containing a modified oracle function definition).
My first tests show, that it had barely an effect at all.
Smiley Frustrated At least it seems not to worsen the problem
