Get Issue Field value by CLI (supporting line breaks)
Hello
I am looking for CLI solution how to get an issue field value with the field being a text with linebreaks. (example Requirement Text field).
I've started parsing the im viewissue output but it is difficult to split between fields and field values.
See example below:
t =
Type: Requirement
Created By: Miller Christian RGB (MILLERC)
Created Date: Sep 14, 2012 1:57:20 PM
Modified By: Wenger Gregor RGB (WENGERG)
Modified Date: Oct 17, 2012 1:45:41 PM
State: New
Project: /PSL/CmbEng/EngOperSt/CA000
Contains:
Contained By: 187542
References: 187582xyz
Reference Mode: Author
Root ID: 187581
Input Revision Date: Oct 17, 2012 1:45:41 PM
Document ID: 187541
Subsegment Name:
Referenced Item Type: Shared Requirement
Category: Functional Requirement
Shares:
Shared By:
Authorizing Change Order:
Suspect Count: 0
Valid Change Order: true
IncludeReference: false
Discussion:
Priority:
Changes Authorized By:
Decomposes To:
Decomposed From:
Is Related To:
Is Related Back:
Text: The time after start (EOS_TiElpdAftStrt) shall be realized with an integrator. If EOS_AcvStrtEnd = 1 shall be count. The integrator shall be set on reset when EOS_AcvStrtEnd = 0.
The time after stop (EOS_TiElpdAftStop) shall be realized with an integrator. If EOS_AcvStop = 1 shall be count. When the signal of EOS_AcvStop rise shall the integrator set on reset.
Text Attachments:
Project Phase:
Trace Status: none
Downstream Trace Count: 0
Upstream Trace Count: 0
Linked Requests:
Requirement Tested By:
Related Development Tasks:
RIF_Attachments:
RIF_Configuration:
RIF_Identifier: d9b7ff3e-b91f-4eb2-9ed3-48780df07860
RIF_ID: 723951712
Requirement Origin:
Requirement Level:
Requirement Safety Standard:
Requirement Safety Levels:
Requirement Rationale:
RIF_Attachments_fva:
Requirement Acceptance Criteria:
Discussed in:
Requirement Summary:
Planned for:
Stakeholder Comment:
Referenced Bookmarks:
Bookmarks:
Reuse Potential:
Approval Customer: clarify
Approval Supplier:
Comment Customer:
Comment Supplier:
System Level:
System Structure Nodes:
Decomposition Summary:
Item Significant Edit Date on Shared Item: Oct 17, 2012 1:45:41 PM
Significant Edit Date: Oct 17, 2012 1:45:41 PM
Stakeholder ID:
RIF_Additional_Info_txt:
RIF_Additional_Info_int:
Forward Relationships:
Backward Relationships:
In bold I've marked the output of the Text field.
It is specially difficult if in my requirement text I have line breaks or : sign used.
I was hoping the im viewissue would support a --field="Text" option like for the im issues (query) but it seems not the case.
So the current solution I have now is in two steps:
Getting the list of all fields by a im viewissue --xmlapi and then parsing the ouput for <Field name="([^<]*)">'.
Knowing the output list of fields, parsing the output of the im viewissue to look for value between Field and the next neighbouring field in the list.
Any better idea?
Many thanks
Kind regards
    KaelLizakAnswer
    Hi Thierry,
    Try im issues --fields=Text <<itemID>> where <<itemID>> is replaced with the ID of the item you want to parse.
    Note that im issues also has a --fieldsDelim argument, that might help when parsing multiple fields in one pass.
    Kael
    KaelLizak16-PearlAnswer
    Hi Thierry,
    Kael
    tdalon1-VisitorAuthor
    Thank you Michael! Perfect answer - also with the hint for the --fieldsDelim option.
    Another solution is to export the items to an excel file (using im exportissues) and read the output Excel file.
    This is much better if you want to read multiple items in one pass.
    Export+to+Excel.PNGWhy wouldn't you use the export to excel function from WEB Client view right click using the menu option as shown in the screen shot attached, you can add all the fields to your view screen to export.
    The question was how to get the field values by script/ command line.
