Get IssueId when creating issue from command line
Hi Team,
I'm using batch file to create new issues ( im createissue) based on certain conditions. Is there any way i can get the ID of newly created item using the same batch file ?
Arun
    mrumpAnswer
    Hi Arun,
    I am not sure whether using the --gui option gives you a result on the command line at all, as you'll get the visual feedback.
    Without the --gui option your command should result in something like:
    Modifying item ...
    Editing fields ...
    Submitting ...
    Updated item <# ITEM_ID# >
    usually the new Item'S ID is the result value of a CLI "im createIssue .... " command.
    Depending on the Integrity Version you are using, this result is either streamed out on STDIO or STDERR.
    So you might have to check both and parse the result.
    akuruvila1-VisitorAuthor
    Thanks for the reply Matthias.
    I was trying to capture STDIO / STDERR using below command - but got empty log file.Could you help.
    im editissue --Field='Description=%DESCRIPTION%' --gui %ITEM_ID% 1>D:/Integrity/log1.txt 2>&1
    **I'm able to get logs for viewissue commands.
    Arun
    mrump16-PearlAnswer
    Hi Arun,
    Modifying item ...
    Editing fields ...
    Submitting ...
    Hi Arun,
    you can use the --xmlapi flag and parse their the command output to extract the IssueID.
    HTH
    Thierry
    Thanks for the reply Thierry.
    --xmlapi also not giving any output when used with --gui.
    Arun
    Hi Arun
    ok. maybe it work for you to first to create the Issue without --gui and then open it with 'im editissue --gui IssueID'?
    or you want the possibility to cancel the issue creation?
    Regards
    Thierry
    You could try the --displayIdOnly option. This has the effect you want of printing the ID of the newly created item. Using Korn you can do something like
    co2=$(im createissue --type="Change Order" <<fields>> --displayIdOnly 2>&1)
    print "Created Change Order issue $co2 and saved ID" >>deploy.log
    Still getting same issue.
    displayIdOnly not returning any value when used with --gui.
    Arun
