Get name of user who created a label
I would like to know if there is a command that returns the name of the Integrity user who created a label attached to a member in Source Integrity. Using "si viewlabels member" i only get the names of the labels and the member-revision they are attached to. Is there a way to get more information about a specific label?
Thanks!
Stephan Knopp
    Hi Stephan,
    Audit logging if enabled and setup on the Integrity server, could aid you in looking this info up, but of course, you would have to have that setup already.  Audit logging is covered in the Integrity Administration guide.  You can enable various Configuration Management actions to capture in audit logging, but "addLabel" is one of them.
