Get Sandbox server info
Hi
Do you know a way to get the server info related to a Sandbox by script?
I would like to connect to the right server for a given sandbox.
Unfortunately the si sandboxinfo CLI command requires to use the rigth hostname.
Many thanks
    tdalon1-VisitorAuthor
    I've found a solution using
    si sandboxes
    command.
