Get the sandbox location based on Configuration Path
Hello, guys.
Is there a way to get the local path of a sandbox based solely on the Configuration Path of the project? I know about the si sandboxes command but this returns the project name, not the configuration path of the project.
Thanks is advance.
    mrumpAnswer
    the "si sandboxes" command only lists all registered sandboxes for the current user (since I10.6 it also lists the according project, but not the config path).
    Take the results from "si sandboxes" and use
    "si sandboxinfo --sandbox=<sandbox>"
    this gives you some detailed information about the sandbox, including the referenced config path
    See the CLI API pdf file for further details
    HTH Matthias
    mrump16-PearlAnswer
    HTH Matthias
    oostoia1-VisitorAuthor
    Thanks, Matthias Rump‌ . This should do the job.
