getting detail information about attachments(Attachments, Shared Attachments, Text Attachments)
I know that getting detail information from a issue(Item) is
in CLI
$ im view issue 2
in Java API
Command cmd = new Command(Command.IM, "viewissue");
cmd.addSelection("2");
In result, I get the fields of the issue(item) that I selected.
Shared Attachments:
shared.txt
Text Attachments:
text.txt
attach.txt
Not just names of the attachments, I want to know the detailed information of for each attachments (text.txt, attach.txt, share.txt...) such as created by and created time.
I know that the detailed information of each attachments is shown in the GUI client when view detail of the item.
How can I retrieve those information by CLI and Java API?
awalshAnswer
Try using the option "showAttachmentDetails".
On the CLI, the output is like:
MKSImg8987741183544506197.png (5567 bytes) awalsh 2-May-2016 9:58:41 PM Attachment added automatically by rich content image/png bfecae030292b268a8f54c9d67454ebe
In the API, you will get:
 Field:
 Name = Text Attachments
 Data Type = mksItemList
 ItemList:
 Item:
 Context = 2892
 Model Type = im.Attachment
 Field:
 Name = FileName
 Data Type = wchar_t *
 Field:
 Name = FileSize
 Data Type = int
 Value = 5567
 Field:
 Name = CreatedBy
 Value = awalsh
 Field:
 Name = DateAdded
 Value = 2-May-2016 3:58:41 PM
 Field:
 Name = Summary
 Value = Attachment added automatically by rich content
 Field:
 Name = ContentType
 Value = image/png
 Field:
 Name = Checksum
 Value = bfecae030292b268a8f54c9d67454ebe
 Field:
 Name = AttachmentID
 Data Type = int
 Value = 46
awalsh5-Regular MemberAnswer
 Field:
 ItemList:
 Item:
 Context = 2892
 Field:
 Name = FileName
 Field:
 Name = FileSize
 Data Type = int
 Value = 5567
 Field:
 Name = CreatedBy
 Value = awalsh
 Field:
 Name = DateAdded
 Field:
 Name = Summary
 Field:
 Name = ContentType
 Value = image/png
 Field:
 Name = Checksum
 Field:
 Name = AttachmentID
 Data Type = int
 Value = 46
mhyang1-VisitorAuthor
Thank you! That works for me.
