Has anyone been able to manage MQSeries script members
I am using MQ series on the iSeries and wanted to manage the 2 script files (a .CLP member and a member without an extension) needed for maintenance in implementer.
They are created with the QSAVEQMGR command and one (the one without an extension) is run as a parameter with STRMQMMQSC command.
I tried to create an MQSCR object code but when I leave the source type blank it gives me an error. When I add a period it does not create a source file member.
Any help appreciated, thanks in advance.
    Scott,
    I am going to open a support case for you.   I will scan the database to see if we have any other customers who have encountered these objects.  If not, we will want to work together to create a new object code.  I will want to see a DSPOBJD of the object and then know the source member type in order to help you create an object code.
    Once we get it working, we will post the results here to help anyone else who may have these objects!
    Dawn
    sdamery1-VisitorAuthor
    The object is like a text file. It is a File member with no file type.
    Similar to an ALTER TABLE script file member only  we are using the TXT file type for those.
    With the ALTER TABLE scripts you create a TXT file member and then use creation command CPYSRCF to move the member through environments, then you use the special command to run it with RUNSQLSTM.
    This would be similar except that is has no file type and the special command to run it would be STRMQMMQSC.
    You could try something like this and then an after move special command (IEXCRQSDTL) to run the STRMQMMQSC
    DSPOBC.1                Display Object Code
    Object code  . . . . . . . . . .     MQSCRPTMQ Script
    Activity flag  . . . . . . . . :   1       1=Active, 0=Inactive
    Object type  . . . . . . . . . :
    Object attribute . . . . . . . :
    Source member type . . . . . . :   TXT
    Default source file  . . . . . :   Q???SRC
    Creation sequence  . . . . . . :   1000    1-ZZZZ
    Special characteristics  . . . :           *DATA, *MERGE, *MAINT, ...
    Object authority . . . . . . . :   *KEEP   *KEEP, *GRANT
    Remove obj in from env . . . . :   Y       Y=Yes, N=No
    Remove src in from env . . . . :   Y       Y=Yes, N=No
    Creation process . . . . . . . :   M       C=Compile, M=Move
    Archive in MKS Source  . . . . :   Y       Y=Yes, N=No
    Creation command . . . . . . . :   CPYF FROMFILE(#WRKSRCLIB/#WRKSRCFIL) TOFILE(
    PGMLIB/#SRCFIL) FROMMBR(#OBJECT) TOMBR(#OBJECT) MBROPT(*REPLACE) CRTFILE(*YES)
    Let me know if you would like to have a webex to experiment with this object code.
