Hello, need help to get Block Diagrams started
    I am a standalone party that is doing independent research.
    I just started the Integrity Modeler and I find that I am unable to create or enter information into Block Diagrams.
Under SysML, I am trying to start building up some Block Definition Diagrams and Internal Block Diagrams.
However, the app will not accept my input.
   I just installed (I believe) the application, after a 30 day trial period.
   If there something I need to do first to get my block diagrams, or some action I need to take, I'd
like guidance on this. I'd like to know if there is something I need to do first.
   When I had No-Magic I just dragged a block over, labeled it, and the system obeyed.
   Now, the system doesn't seem to do anything.@
   Please respond also to -
V/r  Joshua H. Sparber
Joshua, what PTC Creo software are you using?  This area is primarily for Creo Parametric CAD software.
Toby Metcalf‌ can move this to the proper forum once we understand what you are using.
Emeritus
Will do Doug - moving to Integrity
PatrickOllerton
hi Joshua,
Creating SysML models, and BDD/IBD diagrams is very simple.
We need to understand what process you have followed, so can you please describe the exact steps you have taken in Modeler and I will provide more guidance.
Alternatively you can review the Help ("SysML, UML and UPDM profiles\SysML Profile\Blocks" chapter)
There is also a helpful MBSE Tutorial available from PTC Support
https://support.ptc.com/view?im_dbkey=166944
regards,
Patrick
Hello Joshua Sparber‌,
Did Patrick Ollerton‌'s response provide the information you needed to work this issue out?  If so, could you click on the Correct Answer button under his post?  If not, could you let us know what steps you are taking, so that we can try and get you going down the right path?
Kael
