Hostname change results in error in MSSQL database connection with PTC RV&S appplication
I have installed MSSQL Server and PTC RV&S client and Admin in a virtual machine. Now the machine's hostname has been changed and have done below remediation-
  • Got new license from PTC
  • Changed is.properties files by replacing old hostname with new one.
  • Changed the hostname in SQL server management studio with a query.
  • Have checked the TCP/IP port as well.
  • Executed the Telnet to the new hostname and sql port - working
what all steps do I need to follow to remediate the issue and avoid the error. Also is there any need to install the application again as well?
Catalina
Community Manager
Hi @AarushiS
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
