How can I delete an attribute from the roundtrip-configuration ?
I have a doors-module with an already defined attribute.
But now I have to re-create it from a RIF-file [which has to be imported].
Nevertheless if a rename or delete this attribute, it stays valid in the roundtrip configuration and is therefore not imported and raises an error in the report.
Any suggestions ?
Than you,
Thomas MIGLINCI
