Feb 20, 2017 9:29 AM UTC
How can I get the description/text of a test case with substituted parameters via web services?
I am extracting the descriptions of my Integrity test cases via web services (C#) and it works fine.
The only problem is that the parameters are not substituted, they are written as {{myParam}} within the text.
Is there a way to get the field contents with the real parameter values?
    Mar 18, 2018 4:50 PM UTC
    I know that your request is already a bit older. Hope this note still helps:
    http://support.ptc.com/cs/help/integrity_hc/integrity112_hc/en/index.html#page/IntegrityHelp/tm_testcases.html
    Please use "tm testcases" instead of "im" commands.
