How can I insert a link to the project backing item?
is there a chance to insert a link to an item that leads to the project backing item?
For example making the 'Project' field an active link that leads to the Project's backing item?
I can get values from the project backing item by using FVA, but FVA cannot be turned into hyperlink.
I would be thankful for any suggestions.
Chris
    Hello Christoph,
    If you can get the item ID, you can create a hyperlink to any item using the URL:
         http[s]://<ServerName>:<ServerPort>/im/viewissue?selection=<ItemID>
    This opens the item up in the web interface.  The equivalent one for the Integrity client would be:
         integrity://<ServerName>:<ServerPort>/im/viewissue?selection=<ItemID>
    This one requires that the integrity protocol handler is registered with whatever program is doing this.
    Since backing items are just Integrity items of a given type, the above should work.
    References:
    • CS119067 covers creating web UI links to Integrity Manager artifacts.
    • CS187241 covers creating client UI links to Integrity Manager artifacts.
    • Note:  while there is some overlap between the functionality of the above two, there are some links each can follow that the other cannot.
    Kael
    cpabst1-VisitorAuthor
    Hey Kael,
    thank you so much. To be honest. the linking was not the problem - instead I am having a hard time getting the item ID.
    Or to be precise - if have not a clue how this could be accomplished from within the item.
    Any idea of how this could be solved?
    Thanks in advance.
    Best,
    Chris
    From the CLI you could do it with im projects --fields=name,backingissueid. I'm guessing you're trying to do this through a computed field somehow? I don't think that gets you to where you want to be unless your project structure is short, stable, and you don't mind constructing a look-up table of some sort.
    Actually, if you can get the values from an FVA, you should be able to get those values through a computation.
    Out of curiosity, what is your use case for linking to the backing items?
