How can I print information about the label in source control system ?
Hi!
My company manage baseline by label.
so we want to show label in 'view projects' when we use 'shared project' function...
but, I have heard it's not possible...or waiting for being answered of "Idea" page in this site.
then, is it possible to get [project & rivision & label] information when I use 'si report' command ?
I checked that there is  [project & revision] information, but label is not exported.
    alabonteAnswer
    Hello 아름 한,
    To gather the labels from the checkpoints of the project history, we will need to run another command in addition to the one above.
    I have created a batch file that will prompt the user for which Server to connect to, which Port to use, which User to use, which Project you are polling, and the File Name to output the information to. You can copy this batch file and modify it for your use. You can change the fields returned by modifying the --fields argument. For si viewprojecthistory your --fields options are: associatedIssues, author, date, description, labels, revision, and state. For si viewproject your --fields options are: attributes, cpid, labels, memberarchive, memberdescription, memberrev, name, state, symboliclink, and type. You can add/remove and change the order of these --fields options to get the output to your desired organization.
    The bat file:
    ECHO off
    set /p UserInputHostname= Please enter the hostname of the Integrity Server to connect to:
    set /p UserInputPort= Please enter the port that the server is listening on:
    set /p UserInputUserName= Please enter the username to use:
    set /p UserInputProject= Please enter the project name (full path):
    set /p UserInputFile= Please enter the filename for the output file:
    si viewprojecthistory --hostname=%UserInputHostname% --port=%UserInputPort% --user=%UserInputUserName% --fields=description,labels,revision -P %UserInputProject% >> Temp.txt
    si viewproject --hostname=%UserInputHostname% --port=%UserInputPort% --user=%UserInputUserName% --fields=name,type,memberrev,labels -P %UserInputProject% >> Temp.txt
    copy Temp.txt %UserInputFile%
    del Temp.txt
    ECHO Please see %UserInputFile% for the output of project %UserInputProject%
    You can then open the file defined by the user as %UserInputFile% with Excel, using space delimiting, and continue on with Excel as you normally would.
    Hello 아한,
    Thank you for your inquiry to manage Checkpoint (Baseline) by Project Label.
    You can do this in the GUI, when you open a project. The wizard will give you options to open a project, then you can select the type of project to open, Normal, Variant, or Build (Build is then branched off to select by Revision or by Label). Select Build, then Label, and select the label given previous to this Checkpoint(Baseline).
    You can also access this information via the CLI. You can use the command:
    • si viewproject --projectRevision=Label -P /Project/SubProject/project.pj
    아한_011-VisitorAuthor
    Thank you for your reply.
    It is a little different thing that I want.
    Our company want to show like this image. We want to show all subproject's labels of  'test_bd_icu' project. (in that time, all shared projects are build option.)
    But I don't hear about that anything.(I posted up this in 'ideas' broad)
    So I'm finding workaround.
    When I select 'test_bd_icu' project, I export a excel to show all subproject's labels.
    Hello 아한
    You can work around this by using the Command Line Interface. With this interface we can also output to a text file for you to open with Excel, to show all the subproject labels.
    The command is:
         si viewproject --hostname=<1> --port=<2> --user=<3> --fields=name,type,memberrev,labels -P <4> >> <5>.txt
              Where:
                   <1> is the hostname of your server (eg. localhost or DNS name)
                   <2> is the port that your server listens on (eg. 7001)
                   <3> is the username to run the command with
                   <4> is the project to focus on (eg. /Projects/Testproject/project.pj)
                   <5> is the file name to output to
              A completed command should look like this:
                   si viewproject --hostname=localhost --port=7001 --user=username --fields=name,type,memberrev,labels -P /Projects/Testproject/project.pj >> Test.txt
    This will create a file "Test.txt" in the <IntegrityClientInstall>/bin folder.
    You can then open this file in Excel, using space delimiting, and continue on with Excel as you normally would.
