How can we Export Integrity Document into PDF directly rather then Exporting to DOC
How can we Export Integrity Document into PDF directly rather then Exporting to DOC and Converting to PDF ?
Hi Kapil
Please see this:
https://community.ptc.com/t5/Integrity-Blog/Integrity-LM-Server-Gateway-and-Reports/ba-p/448480
search for PDF then.
Best Regards
kjain-21-VisitorAuthor
Hi Volker,
Thanks for your detailed info.
So it's possible by Custom Gateway that is created by You and looks like such a fruitful one for End User.
Is it shareable?
As you already told me it tooks around 50 Dev. Days and appreciate your Effort on this...
Kapil
Hi Kapil,
there are two parts, the custom gateway as described in the link from me, and the custom java classes enriching the Word export. The former was rather 2 days of work only, its in your inbox for testing. The latter is what I described with much more days. This is the solution using the "Gateway Overload" technique and all this was implemented on customer request for specific business cases.
Please test what I have sent you and give me a feedback.
