how do I set Transaction Context in triggers
There is a script command called getTransactionContext in the Server Bean. In the description, it mentions a map that can be used to pass information from one script to the next during a transaction. I cannot find how to set or add to this map however.
Would someone please let me know how to add to this map?
Mark
    mbohanonAnswer
    Hello everyone,
    I figured it out. After browsing one of the MKS_ALM scripts, I found this: sb.getTransactionContext().put("AutoLabel", "1");
    I was confused by the word "get" in getTransactionContext. You can add your own by using .put(key,value)
    Mark,
    You are correct that there is little documentation provided regarding this method. There is an RFC in the system to provide better data for this here: Docs request for getTransactionContext method in the server bean
    Please contact PTC Integrity Support if you would like to be added to this RFC.
    In the meantime, I can give you some examples on how this may be used. This example applies to the document model context, but it might give you an idea of how it works.
    For document model operations, the context map will have the key "operation" set, with value = "<document model op>" where <document model op> can be
    one of:
    createcontent
    createsegment
    insertsegment
    movecontent
    removecontent
    branchsegment
    changesegmentproject
    refmode
    baseline
    removebaseline
    propagatetraces
    segmentroots
    geneology
    viewsegment
    togglereference
    documentedit
    For all other issue edits, there are no values in the context map.
    if operation=createsegment, two key/value pairs are added if there is a parent id:
    parent=<parentID>
    include=true|false
    if operation=insertsegment, one additional key/value pair is added:
    include=true|false
    e.g. if I run the command: im createsegment --insertMode=reference --parentID=971 --type="ALM_Input Document" --field=Project="/ALM_Projects/Release2" --field="ALM_Document Short Title"="test"
    then getTransactionContextMap will return:
    Key: operation Value: createsegment
    Key: parentid Value: 971
    Key: include Value: false
    mbohanon1-VisitorAuthor
    Hello Jeremy,
    Is there any way to create a Key-Value pair? I was interested in having some method of passing information from one trigger to the next since delta beans don't know where they came from (other than Secondary Issue Change).
    Mark,
    This is tricky as I'm not sure that we have a properties class or some kind of thread local storage that we can use to pass around data. What kind of info are you looking to share between triggers?
    mbohanon1-VisitorAuthorAnswer
    Hello everyone,
