How do I setup a trigger to fire when the Document ID changes?
We need to perform some procesing logic when an item is moved from one document into another. We have setup a trigger rule that contrians Document ID != Document ID[New Value], but the script never fires when I cut-content and paste-content. With a little debugging, I'm finding that tne Document ID of the destination document is not available to me in scripts.
Can someone explain to me how to setup a trigger that fires when the Document ID changes for an Item?
Note: In the Trane Solution, the Document model is mostly disabled in this context. No branching, versioning, etc. The document is merely a container and there is no hierarchy to the node items.
    mrumpAnswer
    Hi Sean,
    Have you tried the following:
    1. setup a trigger rule "Contains [new value]" <> "Contains"
    This should fire everytime you manually edit the content of an document is moved.
    2. Also check "Contains" <> undefined
    That should filter the creation of new nodes
    3. inside the triggerscript you can now use the ID of the new and old related Items to get their Document ID.
    If they do not match, run whatever you want to do in your script.
    BTW: You should keep in mind that any ruel based trigger has and effect on your systems performance. If the trigger takes a signifcant amount of time to complete, the users will notice a "slowly responding" UI.
    HTH Matthias
    Hi Sean,
    as far as I know, the Document ID is a computed field.
    I am not shure whether the trigger rule you defined really catches these type of fields.
    Your rule definitely works for a "manual" edits.
    But it seems that (comparable to changes in a source-link field) the rule is simply not evaluated when the result of the DocumentID computation changes.
    A workaround might be a daily or hourly scheduled trigger that uses a "historical" query to identity the Itmes that have a changed Document ID.
    HTH
    Matthias
    Hi Matthias,
    Thanks for the quick response. A schedule-based trigger is not sufficient for our use-case. When a user moves a requirement from one document to another, we need to fire an event and perform some processing logic. Once the requirements are in a new document, the user will want to imediately work on them. So waiting is not an option.
    Our first thought was to use the contains relationship, and that worked for a while. Unfortunately it does work when hierarchies are present. Although we currently are not using hierarchies for these types, we are building some prototypes that use parts of the hierarchical functionality of the Document Model. So the solution to this problem needs to work whether there is a hierarchy in place, or not.
    We switched to a trigger based on changing the Document ID, because it seemed the most straightforward - simply fire off a script when the document changes. Unfortunately, that does not provide the needed functionality. If there are other ways to accomplish the functionality that we need, we are open to them. Please make suggestions, our knowledge of the Integrity engine and the "Document Model" is limited.
    -Sean
    mrump16-PearlAnswer
    Hi Sean,
    HTH Matthias
