Feb 19, 2019 7:45 AM UTC
How Test Cases in Tests field is getting freezed once the Test Session is moved to In Testing state
As per my knowledge Test Cases linked to Test Session in Tests field will not change if the Test Session is moved to In Testing state. That is because TestSession.js trigger sets the Tests As Of date. But I am not sure how Test Cases are prevented from showing the updated information after As of Date. Is there a trigger or in built functionality of PTC?
I am curious to know how this works.
Vikram M
Emeritus
Feb 19, 2019 8:06 AM UTC
@vikramm please can you confirm which product you are using so your query can be directed to the appropriate team?
vikramm1-VisitorAuthor
Feb 19, 2019 8:37 AM UTC
Sorry about that.
PTC Integrity 10.6
Apr 3, 2019 1:36 PM UTC
Hi @vikramm and @Heidi ,
Did you eventually get an answer on this? We are also wondering on this technicality.
Best regards, Nils
Apr 4, 2019 3:57 AM UTC
I didn't get a solution yet:(
