How to add date fileter in "im timeentries.. command
I want to create the command which will give the time entries between two given dates or Time entries of given date.
I tried executing command as bellow but it doesn't work. getting an error as "Invalid option: entryDate"
>im timeentries --entryUser=<Username> --entryDate="21 Aug, 2014"
im: MKS124819: Invalid option: "entryDate"
Usage: im timeentries options...; options are:
        --entryUser=user  A user used to select time entries
        --fields=field1[:width1],field2[:width2]... where fieldn can be any of:
createdBy,createdDate,duration,entryDate,issue,modifiedBy,modifiedDate,notes,sou
rceDisplayName,sourceName,user  The fields to display.....
Please help me with this.
    Hi Adhik,
    If you run 'im timeentries --usage' you can see all available options for the command. In that list of options is --filter which can be used for entrydate.
    im timeentries --filter=entrydate:<date>
    Hello Adhik Kadam,
    I agree with Joe.  If you are having difficulty with his suggestion, please let us know.  If it solves your problem, please click on the Correct Answer button at the bottom of his response.
    Kael
