How to constrain a field according to a user group ?
I wonder if it possible to constrain a field according to a user group? If my field contains valueA, valueB and valueC, only valueA and valueB will be displayed if I'm part of group1 and only valueC and valueA  will be displayed if I'm part of group1.
Thanks in advance
Frédéric.
Hi Frederic,
I think you can set constraint on pick filed like value is A and B if user is part of this group and value C if user is part of other group. I think this way you can do or you want me to implement and sent you an snapshot. Tell me which is convenient for you.
Waiting for your response Frederic.
Regards
Kapil Jain
Frédéric,
Open your Integrity Admin GUI, go to "Workflows and Documents" > "Types".  Select the "Type" your wish to create a constraint, then press Ctrl + E.  Click on "Constraints".  There are fours types that you can create 1) Basic, 2) Field Relationship 3) Rule 4) IBPL.  I suspect you would need a Rule constraint.
Hope that helps.
Dan
Hi Daniel,
Yes you are right,  Frederic need Rule constraint in this way (Current User is part of this group) then Only Pick value A and B will visible ow Value C will visible.Hope this helps. If any issue revert me back.
Regards
Kapil Jain
