How to create a hyperlink to a query to open up on the web interface?
I want to create a hyperlink to a query in a meeting agenda for attendees to be able to click on to see what items we are going to go through. Could anyone please help we with how I would create this hyperlink?
Sam
    tketzAnswer
    Hi Sam,
    Run A Query: http://{hostname}:{port}/im/viewissue?query={queryname}
    more information can be found in the knowledge base article:
    CS119067 https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS119067
    tketz1-VisitorAnswer
    Hi Sam,
    The hyperlink syntax, after the protocol/hotname/port prefix is: /im/issues?query=Your Query Name Here
    You should encode the spaces as %20 if necessary, depending on how you use the link.
    Another useful one is /im/runreport?selection=Your Report Name Here
    sfenton1-VisitorAuthor
    Thanks guy!! This worked like a charm.
