How to create a report containing Test Cases, Test Steps and Verdict?
I am trying to create a report containing Test Cases, Test Steps and the Verdict, all belonging to a single Test Session. The standard PTC article only gives examples on how to create this report without the Test Steps, and the report they refer to is only editable in HTML. How can I add test steps when there are no field to select the steps?
Anyone has some experience with this?
Regards, Nils
Hello Nils,
if I am not mistaken there is a good chance to get also the steps + results into an html export.
But nevertheless, I created already some years ago a backpack for the Gateway, to get directly a Word/PDF file for individual Test Sessions with results. (see attachment)
It requires a local configuration incl. an additional java class.
Let me know if you are interested, then I can send you further details.
Volker
NilsN1-VisitorAuthor
Hi Volker,
Thanks for your reply! Something like the example you've attached would indeed be what I am looking for.
If you could share some more details with me that would be great!
Regards, Nils
