How to create a Trace between two documents contents which are inserted from two different parent ?
How to create a Trace between two documents contents which are inserted from two different parent where they linked each other?
Parent Doc_A 1322 : 100 contents available
Parent Doc_B 2322 : 80 contents available
here contents from 1322 & 2322 are interlinked with each other..
We have another two documents Doc_C & Doc_D
Doc_C 3322 : 20 content available
Doc_D 4322 :  30 content available
Later 20 contents get inserted from Doc_A to Doc_C and
also 25 contents get inserted from Doc_B to Doc_D.
Now How to create the trace relationship between newly inserted contents in Doc_C & Doc_D ?
As Doc C & Doc D are not branched document so here Propogate trace to.. cant work, also copy-paste special option available but it links possible between Doc A & Doc C. Is there any way to make relationships between C & D's newly inserted contents?
Hi Chittaranjan,
well, quite interesting use case, whats the business background? Any picture please that illustrates the situation?
First question: do you copy or move the nodes over from Doc A to Doc C?
Second: You just want to make sure that the traces which were in the Doc C to Doc D are kept after you copied/moved, correct?
Volker
