May 18, 2015 1:10 PM UTC
how to create relateditem with mks
Hallo,
i have a problem to create a SW-Subtask with im createissue.
I use the following commandline:
(1) im createissue --Field="Project=/XX/YY" --Field="SWI=ZZ" --Field="Summary='my summary" --Field="Assigned User=me" --type=SW-Subtask --Field="Observer=he"
Creating SW-Subtask ...
Editing fields ...
Submitting ...
Could not save item: Cannot change the state to IMPLEMENTATION:
There's no parent of type SW-Task.
Then i used the following commandline:
(2) im createissue --Field="Project=/XX/YY" --Field="SWI=ZZ" --Field="Summary='my summary" --Field="Assigned User=me" --type=SW-Subtask --Field="Observer=he" --Field="parent=196" (196 is the parent workitem ID)
I got :
Editing fields ...
Submitting ...
Could not save item: bitIndex < 0: -951
Could you please provide to me the correct solution to create a workitem with a predifined parent?
Thanks and regards
Miled Attia
    tketzAnswer
    Jun 3, 2015 12:01 PM UTC
    Hi @all
    I'm the administrator of the integrity system at Attia's company.
    I solved his problem by explaining our Process-Model (Request->SW-Task->SW-Subtask) and give him the right Syntax:
    im createissue --type=SW-Subtask --field="Project=/MKS/MKS Test" --field=SWI=Undefined --field="Assigned User=xxx" --field=Observer=xxx --field=summary=testsub --addFieldValues="Backward Relationships=166286"
    where 166286 is the parent Item (SW-Task in correct state)
    Best Regards,
    Tobi
    May 19, 2015 5:58 PM UTC
    Hallo Miled,
    Do you have a stack trace from your server's server.log file? You might need to turn up DEBUG logging, but I don't think that will be necessary for this issue.
    Kael
    May 29, 2015 5:37 PM UTC
    Miled,
    Did you resolve this issue successfully, or are you still stuck?
    Kael
    May 22, 2015 7:41 PM UTC
    If you are working with documents and content nodes, you will need to use slightly different commands. For example:
    rq createcontent --type=SW-Subtask --field="Assigned User=[username]" --field="Summary=My Summary" --field=SWI=ZZ --field=project=/XX/YY --parentID=[ID of node or document]
    mattia1-VisitorAuthor
    Jun 2, 2015 3:13 PM UTC
    Hi Joe,
    ich have tried to use this method, but i got the following error message.
    **** The Type "SW-Subtask" is not a node type.
    Regards
    Miled
    Jun 2, 2015 4:02 PM UTC
    In that case, the SW-Subtask type can't be created with rq createcontent.  The rq createcontent command only works with content (node) types.
    tketz1-VisitorAnswer
    Hi @all
    Best Regards,
    Tobi
    Jun 3, 2015 12:05 PM UTC
    Thank you all for your Help and for the quick Reply!!
