How to create requirement document using template in Integrity
There are many document types in our organization we were planning to create templates in Integrity which can be used, im not able to get the option how to do so. Could anyone please share link or article which can help?
elvAnswer
Hello Shilpa,
Then you may go to admin client -> Queries, find a query named Finder Template Projects.
You can edit this query definition, there should be such a filter: Classification = "Template"
You can add Library to this filter: Classification = "Library","Template", so that both Library and Template project documents can be selected as template document when using Create From Template
Eric
Hi Shilpa,
Generally the documents under /Templates project can be used as a template document to create from (if your solution has been configured properly).
For how Create From Template function works or how to configure, you may refer to article CS136993
Eric
Hi Eric,
Thanks for your reply. But I'm looking for the creation of templates using libraries.
Shilpa
elv5-Regular MemberAnswer
Hello Shilpa,
Eric
