How to drop, forget, old sandboxes (v2007 to 10.x)
We upgraded our Integrity system from v2007 to 10.x this summer and I personally am now struggling with trying to remove old sandboxes.
Whenever I try dropping via menu, I get messages like:
"Failed to drop sandbox /users/<...>/project.pj:
MKS125217: The sandbox file
/home/<...>/project.pj is not registered as a top
level sandbox."
I am at the point where I just want to have Integrity Client simply forgetting all notions of old sandboxes.
Removing $HOME/.Integrity* and $HOME/.mks entries doesn't seem to help.
Does anyone know where else information about sandboxes may be stored....?
    I think sandbox info is stored in User/SIDist folder. Removing this folder should unregister all sandboxes.
    Stephan is correct. The SIDist directory in the user's home directory contains the sandbox registry information. If you want to just have *all* those sandboxes unregistered, deleting or renaming that directory will accomplish that. Note that the sandbox folders and files will not be deleted or removed via this method and it would be possible to Import the sandboxes again if you so chose.
