How to export Integrity document with content as per baseline in excel via CLI option ?
Normally we use to export document via "Export to Excel" button on client directly, and the column configure views are exported into excel.
The same should be possible with CLI, do we have any CLI available?
kjain2Answer
Hi @Chittaranjan_11
About baseline i am not sure, but there is an CLI which you can check if it helps you:-
im exportissues
exports query results to Microsoft Excel
Vielen Dank / Many Thanks,
Kapil Jain
kjain214-AlexandriteAnswer
Hi @Chittaranjan_11
im exportissues
Kapil Jain
Hello Kapil,
I tried with the following command but it seems an error, could you help to export document with contents via CLI ?
im exportissues --querydefinition=(walkdocordered[<docID>]) --asOf=<Label> test.xls
im: MKS124823: Invalid option "asOf": You can specify only one of: as of, query, query definition or a query definition file for the same operation.
