8-Gravel
How to filter for members with certain labels
The Project Manager did not checkpoint his project but only applied labels to members.
Now, he is trying to retrieve all members which have a certain label.
The Filter feature in Configuration Management, "Members at Label", only applies to whatever exists on the current configuration of the project.
Is there a way to find all members of this project (also the dropped ones) that have a certain label? Maybe a CLI command?
Thank you
cristina
    mrumpAnswer
    Hi Christina,
    1. if you want to fetch the revisions that own the required label, you need a sandbox, as the project-view can only show you the current member revision by design.
    If you create a sandbox of your project and use the check-out command recursively you can define a "filter" which revision is to be checked out ( e.g. "revision with label" or "last revision with state").
    to create a checkpoint for this "locally restored configuration" your could use the Snapshot Sandbox command.
    1.1 A second option is to create a development path, based on your latest checkpoint and to use the "update member revision" command on this development path. It offers the same "filter" for the revisions to be set, as the checkout command.
    2. the initial checkpoint 1.1 is always empty (by design). If your project manager only applied labels in the past and never created a checkpoint, you will have to reconstruct the configuration manually as described above.
    Hopefully you have changepackages that might help you in reconstruction.
    HTH
    Matthias
    (copied from Client Help)
    "Members at Label"
    Shows only members that have the specified label assigned at the member revision. If you choose this filter, Integrity prompts you for the target label.
    "Members with Label"
    Shows the members with the specified label somewhere in their member history. If you choose this filter, Integrity prompts you for the target label.
    As far as I know it is not possible to filter for "dropped members with label" , as dropped member are not part of the project configuration the filter is applied on.
    You could try to find the Change Packages that contain drop member operations for your project and inspect the history for the found entries.
    HTH
    chariuc8-GravelAuthor
    8-Gravel
    Actually, the "Members with Label" shows the member with the given label, but not the revision having that label but the member revision.
    Meaning that if member a.c got label "x" at revision 1.11, after applying the filtering I will see the member a.c revision 1.13.
    What I would like is to see revision 1.11.
    But anyway, for me, "Members with Label" filtering does not give any result.
    It must be that the filtering is based also on the checkpoint, I guess.
    The problem might be that the initial checkpoint of the projects is empty. Then, the Project Manager only applied labels to members without checkpointing the project.
    Now, he wants to obtain all revisions of files having a certain label.
    Any hints?
    cristina
    mrump16-PearlAnswer
    Hi Christina,
    HTH
    Matthias
    8-Gravel
    Hello Matthias,
    Thank you for your help.
    I did a check-out without lock recursively with the "filter" for the label and solved the problem.
    BR
    cristina
