Jul 24, 2025 6:19 AM UTC
How to Generate "integrity://si/viewproject" URLs for Windchill RV&S Projects?
Version: Windchill 13.0
Use Case: To create e-mail with URL to open specific project, currently I manually type link like following. "integrity://localhost:9001/si/viewproject?project=%2FTestProject%2Fproject.pj" (suggested in documentation.) How can I easily generate such URL?
Description:
I'm looking for an efficient way to generate URLs that directly open a specific project folder (e.g., .../project.pj) in the Windchill RV&S Client GUI. My goal is to use these URLs in email notifications.
What I've found so far:
  1. Manual URL Entry: I've found documentation on how to manually construct these integrity://... URLs to open projects, but manual typing is prone to errors.
  2. Automatic URL Generation (Partial Success): The documentation states:
    "You can create e-mail notifications with Windchill RV&S client URLs by clicking a highlighted user name in any visible field in the GUI or Web."
    I've successfully used this method to generate URLs that invoke the im (Integrity Manager) command.
My Challenge:
I need to generate URLs that invoke the si (Source Integrity) command to view a project, specifically in the format similar to:
"integrity://localhost:9001/si/viewproject?project=%2FTestProject%2Fproject.pj&filtersubs"
The issue is that when trying to select a source project in the GUI, there isn't a "highlighted user" element to click on that would generate an si command URL. The method described seems to be specific to user-related im commands.
My Question:
Is there an easier, automated way to generate URLs that open specific project.pj folders using the si viewproject command within the Windchill RV&S Client GUI? I'm trying to avoid manually constructing these URLs.
Any advice or alternative methods would be greatly appreciated!
Thank you.
ssaulAnswer
Aug 1, 2025 6:10 AM UTC
we implemented auto-creation of URLs via server triggers, but also via custom actions and VBScript.
It is a larger script, I have extracted the relavant parts of it for URL creation (see attachment).
It is called (as custom script from within RV&S) via
wscript.exe "C:\pathtoscript\VBScript.vbs" /i
It will create an output like
****** Web link:
http://ourservername:7001/si/viewrevision?projectName=d:/ServerPath/project.pj&revision=:memberbranchtip&selection=Archivename
****** GUI Project link:
integrity://ourservername:7001/si/viewproject?project=d:/ServerPath/project.pj
****** GUI Project link (Member):
integrity://ourservername:7001/si/viewproject?project=d:/ServerPath/project.pj&selection=Archivename
****** GUI File History link:
integrity://ourservername:7001/si/viewhistory?project=d:/ServerPath/project.pj&selection=Archivename
Hope it helps to give you a starting point.
Emeritus
Jul 30, 2025 7:18 AM UTC
Hi @NKen_521,
Thank you for your question.
Best Regards,
Vivek N
Community Moderation Team
ssaul15-MoonstoneAnswer
****** Web link:
NKen_5214-ParticipantAuthor
Aug 4, 2025 2:54 AM UTC
Thank you so much for the helpful reply! The example scripts for retrieving information from Windchill and generating a URL are a huge help. Now I know where to get started.
