Aug 7, 2019 11:24 AM UTC
How to get checkpoint number of every subproject
Hello together,
what I'd like to do is to get the most recent checkpoint number of a project and any of it's subprojects.
Is there any possibility to do so?
What I've tried so far is to display every subproject with si viewproject --filter=attribute:name=project.pj -R and to display the history of a project with si viewprojecthistory --fields=revision, but as I'm new to PTC, i don't know how to combine them.
Thank you in advance.
Aug 12, 2019 3:56 PM UTC
To get the most recent checkpoint for a project, you can use si projectinfo. The last checkpoint is listed.
For example:
D:/private/IntegrityServers/12.0>si projectinfo -P#/master
Project Name: /master/project.pj
Repository Location: /master/project.pj
Server: abuchanan0l:7120
Configuration Path: #/master
Restricted: false
Last Checkpoint: 1.15
Last Checkpoint Date: 29-Mar-2019 10:16:37 AM
To get a list of the checkpoints in the subprojects, you can view the project at the last checkpoint with a filter to show only subprojects.  For example, using the last checkpoint 1.15 as the build number for the project:
D:/private/IntegrityServers/12.0>si viewproject -P#/master#build=1.15 --recurse --filter=file:onlysubs --fields=indent,name
 subproject1/project.pj (1.4)
 one/project.pj (1.4)
 two/project.pj (1.2)
 red/project.pj (1.1.1.1)
 subproject2/project.pj (1.3)
 blue/project.pj (1.2)
 test/project.pj (1.11)
 auto/project.pj (1.3)
 config/project.pj (1.1)
 Inputs/project.pj (1.2)
 new/project.pj (1.2)
 auto2/project.pj (1.2.2.1)
 config/project.pj (1.1.2.1)
 Inputs/project.pj (1.2.2.1)
 new dir/project.pj (1.7.2.1)
 auto3/project.pj (1.3)
Note on the filter: Any filter which excludes all members will work. I use "--filter=file:onlysubs" because I find it easy to remember and it's clear what the output will be.
