How to identify the list of change package between each checkpoint
Anyone know how to find the list of changepackages made between checkpoints
Eg:
Need to identify the changepackage made between 1.3 to 1.4 ?
Shankar
    tketzAnswer
    Hi Shankar,
    you can use the Project History for that case.
    With GUI:
    Select in Project History both Checkpints (1.3 and 1.4) with Strg-Key hold.
    Then Click "View Project Difference" (should take some time). In the new Window you can have a look at all changes and click on tab "By Change Package"
    With CMD:
    si mods -r 1.3 -r 1.4 --project="yourProjectPath" --showChangePackages
    Best Regards,
    Tobi
    tketz1-VisitorAnswer
    Hi Shankar,
    With GUI:
    With CMD:
    Best Regards,
    Tobi
    Hi Tobi,
    Thanks for your update, We can achieve the same using
    View project difference under Change Package.
    Step 1: Select two check point eg: (R1.3 hold key and select R1.4)
    Step 2: Right click and view project difference
    Step 3: Select the tab By Change Package
    Shankar
