Sep 8, 2018 11:16 PM UTC
How to maintain a sub-project with the possibility of each checkpoint with different content?
Hi all
The main project (or parent project) I use have my application and also couple of sub-projects that is delivered externally. The sub-projects can have the folders, source files (mainly the .h, and I use the libraries from them) changes for each release, i.e. a folder can be renamed, removed similarly header files can be removed, renamed or new header files can be added. Now I create a new sub-project whenever I get a new delivery, so I have to always link the new sub-project to the parent project.
Is it possible to have one sub-project with a check-point, and the new delivery can be checked-in on top of the old check point, but just have the files and folders only based on the new delivery ? By doing this I don't have to create a new sub-projects every time and also the linking.
nkm2018
Sep 12, 2018 12:16 PM UTC
Provided you have external_LIB1\project.pj
What do you mean with "linking"? Something like this
external_LIB1_V1\project.pj
external_LIB1_V2\project.pj
external_LIB1_V3\project.pj
+ working subproject as Integrity share to external_LIB1_Vx\project.pj or a build/checkpoint of it
external_LIB1\project.pj (1.3)
(see Subproject->Add Shared)
or "link" to new directory in your build system?
nkm20181-VisitorAuthor
Sep 12, 2018 3:47 PM UTC
Hi @kthierer,
I think you are nearly right, however I'll explain the scenario bit more (also I'm new to integrity so please bear with me).
Main_Project.pj
 + My_app\project.pj
 + External_app_V1.0\project.pj
In the above Main_Project, External_app_V1.0  will have different contents to the External_app_V2.0 (this being the latest delivery of the same sub-project)
Therefore for every new delivery of External_app, there is a new sub_project created (with different names, mainly by using the version number attached to the name).
Ideally I want to use the one sub project External_app - so I don't have to create new sub-project and link them to Main_Project.pj every time.
Sep 12, 2018 5:48 PM UTC
You can have just one subproject External_app. With each new version, you can either update just the changed files, or you could just drop everything in the External_app subproject and add in the files and folders for the new version. It depends how different the versions are.
I recommend creating a checkpoint with a descriptive label whenever you update the subproject. That way, it's easier to retrieve older versions of External_app if necessary.
