Mar 23, 2018 10:26 AM UTC
How to make the Jenkins local Client configuration working
We have a Jenkins Environment up and running with the PTC Integrity Plugin V 2.1.
Running Jobs on slave machines using the remote connection works, but is slow.
To improve the performance we are trying to make the new local Client configuration work.
However, we are running into two problems:
1. When using an Integrity Source Project that is not named Project.pj we get an error:
for : #p=/Test/Test.pj
Preparing to execute si projectinfo for #p=/Test/Test.pj
[LocalClient] Executing Sandbox Verification
[LocalClient] Executing si sandboxes
[LocalClient] si sandboxes response:0
[LocalClient] Searching Sandbox: : D:\workspace\TestPTCLocalClient, for Project Config: [/Test/Test.pj], Build Revision: [null]
[LocalClient] Sandbox not found in : D:\workspace\TestPTCLocalClient, for Project Config: [/Test/Test.pj], Build Revision: [null]
[LocalClient] Executing CreateSandbox :D:\workspace\TestPTCLocalClient
[LocalClient] CreateSandbox response:0
[LocalClient] Clean Copy Requested :true
[LocalClient] Starting Resync Task..
[LocalClient] Executing IntegrityResyncSandboxTask :D:\workspace\TestPTCLocalClient
[LocalClient] Executing ResyncSandbox :D:\workspace\TestPTCLocalClient
[LocalClient] IntegrityResyncSandboxTask invoke Exception :MKS125216: The sandbox file d:\workspace\TestPTCLocalClient\project.pj is not registered with the system.
hudson.AbortException: [Local Client] Failed to resync workspace!
2. When using a Project that is named Project.pj we get following error:
[LocalClient] ResyncSandbox Response:0
java.io.IOException: remote file operation failed: D:\workspace\TestPTCLocalClient at hudson.remoting.Channel@3f13f578:JNLP4-connect connection from <hostname>:56654: java.io.FileNotFoundException: \var\jenkins_home\jobs\TestPTCLocalClient\builds\23\changelog.xml (The system cannot find the path specified)
 at hudson.FilePath.act(FilePath.java:993)
 at hudson.FilePath.act(FilePath.java:975)
 at hudson.scm.IntegritySCM.checkoutUsingLocalClient(IntegritySCM.java:441)
 at hudson.scm.IntegritySCM.checkout(IntegritySCM.java:396)
 at hudson.scm.SCM.checkout(SCM.java:495)
 at hudson.model.AbstractProject.checkout(AbstractProject.java:1276)
 at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:560)
 at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
 at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:485)
 at hudson.model.Run.execute(Run.java:1735)
 at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
 at hudson.model.ResourceController.execute(ResourceController.java:97)
 at hudson.model.Executor.run(Executor.java:405)
Caused by: java.io.FileNotFoundException: \var\jenkins_home\jobs\TestPTCLocalClient\builds\23\changelog.xml (The system cannot find the path specified)
 at java.io.FileOutputStream.open0(Native Method)
 at java.io.FileOutputStream.open(Unknown Source)
 at java.io.FileOutputStream.<init>(Unknown Source)
 at hudson.scm.localclient.SandboxUtils.generateChangeLogFile(SandboxUtils.java:288)
 at hudson.scm.localclient.SandboxUtils.resyncSandbox(SandboxUtils.java:274)
 at hudson.scm.localclient.SandboxUtils.resyncSandbox(SandboxUtils.java:247)
 at hudson.scm.localclient.IntegrityResyncSandboxTask.invoke(IntegrityResyncSandboxTask.java:58)
 at hudson.scm.localclient.IntegrityResyncSandboxTask.invoke(IntegrityResyncSandboxTask.java:18)
 at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2739)
 at hudson.remoting.UserRequest.perform(UserRequest.java:153)
 at hudson.remoting.UserRequest.perform(UserRequest.java:50)
 at hudson.remoting.Request$2.run(Request.java:336)
 at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
 at java.util.concurrent.FutureTask.run(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
 at hudson.remoting.Engine$1$1.run(Engine.java:94)
 at java.lang.Thread.run(Unknown Source)
 at ......remote call to JNLP4-connect connection from <hostname>:56654(Native Method)
 at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1545)
 at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
 at hudson.remoting.Channel.call(Channel.java:830)
 at hudson.FilePath.act(FilePath.java:986)
 ... 12 more
ERROR: [Local Client] Exception occured during checkout! remote file operation failed: D:\workspace\TestPTCLocalClient at hudson.remoting.Channel@3f13f578:JNLP4-connect connection from <hostname>:56654: java.io.FileNotFoundException: \var\jenkins_home\jobs\TestPTCLocalClient\builds\23\changelog.xml (The system cannot find the path specified)
Finished: FAILURE
This error does not appear when using the remote Connection instead of local Client Connection.
Can this error be related to our architecture?
Jenkins Master Server on Linux (actually a docker Image), Build Slave on Windows?
Any help is appreciated, thanks.
Mar 26, 2018 5:29 PM UTC
Hello Florian,
this error suggest that, there isn't specified location present or the sandbox is not registered with the user.
It seems, if Jenkins executing the build where host machine is with linux OS then it would be failed with this error.
Also, is user running  the build with same username as Integrity?
Here is the article CS118994 for more details.
Amit
fbamberg1-VisitorAuthor
Mar 27, 2018 11:47 AM UTC
The Jenkins Setup is working fine, it's only the local Client Integration that makes trouble.
Please note that it works with Integrity Projects named other than Project.pj.
