How to open a URL using Trigger?
Currently I've a requriement, whenever a defect or item is created I need to open one url via trigger. Let me know what is the code to open an URL via trigger?
Thanks & Regards,
shankar
    Do you want to open up the Integrity web client to a specific item/object or do you want to open a browser to an external website?
    I want to open a external website(JIRA URL)
    Anyone know how to open a URL from a remote machine?
    Shankar
    Hi Shankar,
    I'm looking for a similar solution in a different use-case.
    I would like to trigger my build server (Jenkins) when checkpoint is created in Integrity (and the project meed some special conditions).
    So basically I need a way to KICK-OFF the "run build URL" on my Jenkins from inside my Integrity java script source trigger.
    Of course the trigger must be non blocking.
    Did you find a solution so far?
    Regards Matthias
    3-Newcomer
    Hi Matthias,
    I can provide a solution for your use case (we have the same use case):
    var eb = bsf.lookupBean("siEnvironmentBean");
    var pb = eb.createProcessBuilderBean();
    pb.setCommand("wget -q --spider --no-check-certificate --http-user=xxx --http-password=yyy https://zzz);
    pb.start();
    Regards, Ingo
    Thanx Ingo, you just saved my day
