Mar 17, 2016 10:02 AM UTC
How to pass the parameter in Walk Query Section?
I don't how to pass parameters in the walktestsession Query?
for(var i=0;i<testSessionsDetails.length;i++)
tempSessionID=testSessionsDetails[i].toString();
<%beginrelationshipsdetail Query[(walktestsession[tempSessionID])]%>
alert("<%Relationship Expected Results%>");
<%endrelationshipsdetail%>
If I pass the value directly then it is working fine, but if we try to assign either Integer or String value then it is not accepting.
<%beginrelationshipsdetail Query[(walktestsession[“3856”])]%>
Any help would be really appreciated.
Thanks in Advance,
Sithik
    Apr 12, 2016 12:34 PM UTC
    Hi Michael,
    There is some limitation to this.We can't pass the variable in the tag.
    The below tags works for me
    <%RelationshipL2 Tests As Of Date%>
    <%beginrelationshipsdetailL3 Query[(walktestsession[<%RelationshipL2 ID%>])]%>
    Sithik
    Apr 11, 2016 3:21 PM UTC
    Hello Sithik Rahamedhulla,
    When you dump the tempSessionID in the first example, is it the actual item ID or is it some other value?
    Kael
    Apr 12, 2016 12:33 PM UTC
    Hi Kael,
    Sithik
    Apr 11, 2016 11:44 PM UTC
    Sithik,
    Assuming like Kael mentioned, that your tempSessionID, is resolving to what you expect, does this format work for you?
    <%beginrelationshipsdetail Query[(walktestsession[<%<%tempSessionID%>%>])]%>
    srahamedhulla1-VisitorAuthorAnswer
    Hi Michael,
    Sithik
